2007-07-25
11:20 AM
- last edited on
2023-05-23
05:07 PM
by
Rubia Torres
2007-07-25 11:32 AM
2007-07-25 11:51 AM
2007-07-25 05:00 PM
2007-07-26 03:29 AM
majamaja wrote:For this situation you can use a sloping column.
Hey!
I'm new in Archicad and i don't know how to rotate an object in 3d. How do i rotate (for example) a vertical pole that it seems as it's falling down?
Thanks for help!
2007-07-26 04:00 AM
Eric wrote:I'm certain that David Nicholson-Cole, author of the GDL Cookbook, appreciates the promotion.
If you understand basic GDL, you can add a rotate command/parameter to the 3D script of any object. The old bar joist objects would not rotate to be used as a roof joist, so I simply added that parameter. The 2D script needs adjustment too if you want to get picky. The Help Menu has a GDL manual or just buy Dwight's GDL CookBook. It will open up many possibilities! (I do accept sales commissions Dwight!)
2007-07-26 09:18 PM
rob wrote:Yes to Objectives, it doe it all and more..more is the point
You can't in Archicad natively but there is an excellent plugin called Objective by encina which is worth a look up - does lots of useful things that archicad should have implimented about 2 versions ago - but maybe they dont want to give us everything too early on otherwise we wouldn't bother upgrading!
2007-07-27 12:18 PM
majamaja wrote:thats a long time wish !
Hey!
Thanks for help!
2007-07-30 03:24 PM
NeckoFromSarajevo wrote:Easy Necko ... you will turn to The dark sidemajamaja wrote:thats a long time wish !
Hey!
Thanks for help!
Archicad is not modeling software ! I hate archicad and i love archicad !
Archicad 11 SUX
