Rotate/Flip stair numbering?
Attached is a picture of a stair ive designed - its consists of two separate stairs which are combined to make a more complex stair than archicad will produce.
The numbering on the first stair is on the inside run of the stair (number 1-4) whilst the numbering on the second stair is on the outside (5-23) - is there a way in which I can flip the numbering to make it consistent?
Richard
5 Replies 5
Mirror the Short Straight Stair with its longitudinal axis as the mirror axis.
Great - Thanks very much!
Ernest Atanasiu
By any chance is it possible to modify the position of the 16th stair number, instead of the middle of the landing to be positioned like 1-15?
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 11
It doesn't seem to me that it is possible.
If you had a hotspot at the number by which you could drag it into another position, it would be possible, but I don't think there is.
Actually it is kind of weird why it is at that position and not where it should be.
Looks like it is going in the centre of the landing the same as it is for tread 4.
Just put a white solid fill over the number and then type in your own text.
Not ideal but if the object won't allow you to move the text then this is easier than trying to edit the object script to do it.
