Rotated Grid
Is there a way I can stop ArchiCAD from snapping to non-rotated grid.
(I have a rotated grid that is about 1 degree off of the normal setting. My mouse constraints always want to snap to the non-rotated grid so I have to constantly watch to make sure things don't go askew.
Thomas Allan Palmer
Architect AIBC MRAIC
ArchiCAD 24 MacBook Pro
Mac OS Catalina 10.15.6
3 Replies 3
Dontknow
Either you use your 'ortogonal grid' or your 'rotated grid'.
When you use your 'rotated grid' you shouldn't use mouse constraints because then you're drawing a staight line occording to your 'orthogonal grid'.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Have a look in your Work Environment > Mouse Constraints and Methods.
Try turning off the Horizontal-Vertical lock.
And make sure Horizontal-Vertical to Rotated grid is on.
Thanks Barry / Dontknow
Thanks for your advice:
I found the following settings that work (see attached)
Thomas Allan Palmer
