Rotated Project Zero
In the pre-design phase of a project I am working on, we chose to orient our 3 winged building a specific direction. Now further on in the project the lobe of the building we based our x/y direction on has been rotated, resulting in none of the 3 lobes of our building being perpendicular to our project zero.
I know how to use rotated views to fix this in relation to the sheet views but would like to rotate the actual project zero 10 degrees, this will fix the building section markers which are showing up with rotated callout tags even with rotated views.
Does anyone know if it is possible to rotate the entire project 10 degrees? Otherwise I will have to grab everything, group it and rotate 10 degrees off of zero, zero.
Any help would be appreciated.
Thx.
1 REPLY 1
vistasp
Something similar was discussed recently Josh. Have a look at this thread.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
