2010-01-08
10:32 PM
2023-05-23
02:58 PM
Rubia Torres
2010-01-09 01:43 AM
2010-01-09 02:21 AM
2010-01-09 03:18 PM
mc0m wrote:OBJECTiVE provides a
I am trying to figure out how to pitch a vaulted roof.
I've tried selecting the roof in the elevation window, but the rotate element command is not available.
2010-01-09 06:17 PM
2010-01-11 03:57 PM
2010-01-11 04:00 PM
2010-01-11 07:41 PM
2010-01-11 09:14 PM
mc0m wrote:It will still work. You just need to make sure the beam has a higher priority number than the wall, then SEO as normal. For example if the wall is 8, then the beam needs to be 9 or higher.
On the other hand, I need for the pitched element to do an upwards extrusion of the wall that it is resting on. That was a very straightforward SEO when the element was a roof. Now it is a beam, and they have intersection priorities which are odd numbers. The intersection priorities of the wall are even numbers ... so the SEO can't happen.
2010-01-11 10:47 PM
