ā2010-03-03 05:15 AM
ā2010-05-28 07:36 AM
ā2010-05-29 12:15 AM
ā2010-05-29 02:21 AM
ā2010-05-31 05:45 AM
Greg wrote:It is all a bit confusing if you start thinking about the angles.
Thanks vistasp. My confusion has to do with the relationship of north in the dialogue box with north in the plan window. (Why doesn't north in the dialogue box point up, like a map?)
So, is zero degrees on the compass dialogue north or east? Is north toward the right on the dialogue, but toward the top on the plan window? And, if that is true, then when I want the sun to come from due south, I set it at 180, which on the plan window is to the bottom?
Or am I completely off base?
ā2013-03-14 04:06 AM
ā2013-03-14 04:11 AM
ā2013-03-14 01:46 PM
GeorgeC wrote:Object placed directly on the layout updates immediately. Object placed in plan that is part of the placed view needs an "Update".
Currently if I change project north, any north point objects linked to project north do not automatically update in the layouts. I have to manually refresh the layout for the direction of the north point to change. Any ideas?
ā2013-03-18 03:31 AM
ā2013-03-18 03:53 AM
ā2017-11-13 09:06 AM
