SEO in plan view
muril00ng
Hi folks.
I did a SEO with slabs and a object (ellips), and in 3D and section view the representation it's OK. But on plan view, in the respective level, the intersection didn't appears.
What i can do?
Thanks!
3D view:
http://img217.imageshack.us/f/example3dview.jpg/
Plan View:
http://img811.imageshack.us/i/exampleplanview.jpg/
[/img]
____________________________________
Murilo Noleto
http://www.kilobim.com.br/
AC 12 - 27 | Win 10 | 16GB | NVidia GTX 1050Ti | AMD Ryzen 7 1700X
SEO results don't show in plan. The choices are to draw a 2D patch and put the model on a 3D only layer, or convert the results to a library part which will contain it's own editable symbol.
Dwight
I haven't been able to see your images, but:
If your SEO operator slab has an opaque cover fill and its display order is in front of the cut element, it masks the cut parts. Just like a patch would, but automatically - it changes when you edit the slab.
Dwight Atkinson
muril00ng
I did using 3D Document with parallel projection on the top. I moved to Worksheets, where I got the fill corresponding to the real projection.
Then, in the Projects Map, based on the fill, I did the editing of the slabs.
Perhaps there are ways more accurate, but I tried this way and the result was satisfactory.
Sorry for my English, I'm learning this language yet.
Murilo Noleto
