SHowing Core only shows dotted lines at window
I have my vie settings so that my cut plane is below my windows, and my walls are showing the core only and every place that there is a window there is a dotted line at the thickness of the wall finishes.
Do you guys have this problem or know how i can make it go away?
4 Replies 4
Can you change the floorplan view of the window from symbolic or projected to neither?
but i want my windows to show up they way they are-projected with overhead-on the rest of my plans.
Try changing the model view options for the affected view to not show doors or windows (like for a reflected ceiling plan).
That should leave the other views unaffected.
I have my windows turned off in my view settings.
