Strawbale23
SMALL ARCHED WINDOW
Does anyone know how I can model this window??
The Arched Top Window is limited to a minium  height of 1m, I need something that can show height of 40cm.
The half round window is too small,  zero height on the sides
Thanks
AC26
https://www.zendsign.fr/
1 Solution
DGSketcher
Legend
Model it as a morph including a transparent opening material and SEO?
or
apply the New / updated opening tool?
Go to post
6 Replies 6
DGSketcher
Legend
or
Strawbale23
Thanks, you were right, morph object and the new opening tool.
The Opening Tool is impressive....
AC26
Hi Strawbale23, try to model it as arched window with 1m height and finish its lintel as parametric object then convert it to morph then adjust its height to the desired height and back save as window object, it may work.
AC 29 INT 4006/WIN 11
Strawbale23
Thats an idea. I try and edit it in the Parem-O tool as well.
AC26
Jochen Suehlo
Maybe this helps: Fensternische_Stichbogen:
https://www.b-prisma.de/anwender/kostenlos/
Jochen Suehlo . AC12-29 . MAC OSX 26 . WIN11
GDL object creation: b-prisma.de
Strawbale23
Thanks, some interesting GDL objects in there
AC26
