Learn more
sedley
SOLVE ROOF FRAMING PROBLEM
To solve the roof framing problems in the 3rd and 4th Hot fixes for AC12, here is what I did.
1. Install AC12 and update with hotfix 2285.
2. Extract the Object Library 12.
3. Take the RoofMaker Library 12 folder and keep it safe.
4. Update AC12 to the latest hotfix.
5. Update AC12 Library
6. Exract the new Object Library 12.
7. Delete the RoofMaker 12 Library.
8. Put in the RoofMaker Library 12 you kept safe (from version 2285).
9. Load it into AC12.
10. Create a container "Object Library 12".
Use this new library and your roofs will frame properly.
It works for me and my buddies. (Tested on the MAC)
I don't see why it should not work on Windows.
ENJOY
Sedley Jeffers
Sedley Jeffers
St.Vincent & the Grenadines
Archicad 26 Full USA - Cadimage & Twinmotion
MacBook Pro M1 16", 64GB RAM. OSX Monterey
3 Replies 3
RandyC
Sounds good , however we must reinstall previous version , to extract library --- Maybe Graphisoft could post the RoofMaker Library 12 (version 2285) and save us a few steps ?
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
sedley
Hey guys
You can download the RoofMaker Library 12 here.
<ftp://www.architecture.vg:21//Archicad%20Stuff/RoofMaker%20Library%2012.zip>
Sedley
Sedley Jeffers
sedley
Here is the correct link.
I did the earlier one wrong
http://www.architecture.vg/archicad/RoofMakerLibrary12.zip
Sedley
Sedley Jeffers
