SOME of the patterns of the materials missing in elevation
Hello everybody !
The problem is that some of the 3D hatches appear while others don't. As you can see in the images, the pattern of the roof appears normally while the wall's pattern remains hidden. But when I switch to 3D Document, I see all the patterns...
I highlighted the concerned structures in each of the images.
Any help would be appreciated. Thx
Irina[/img]
3 Replies 3
David Maudlin
Irina:
The images are missing, check the FAQ for information about attachments.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Are the missing hatches beyond the Distant Area line? If so check they are on in your elevation settings in the Model Display > Marked Distant Area.
hello and thank you for your reply! i found the solution to the problem..it was about the scale of the hatch..i checked in the hatch editor the second option: scale to the paper size and (it was scale to the model). i hope i translated it well, my archicad is in French.
irina
