Save As Folder
when using the "Save As" function ArchiCAD proposes you to save in the folder where you saved the last file from any project.
This is strange and also annoying because if you work on several projects in parallel it often proposes you the wrong folder with consequent risks of saving files in wrong folders.
I would like that:
- (like most softwares do) ArchiCAD would propose you the folder of the original file that has been opened, or
- for each project you could set a folder that will be always used as default folder for this project for the "Save as" function.
Is it somehow possible with some options/tricks?
0 REPLIES 0
