Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Archicad design tools: Workflows, element connections, modeling tips
Save backwards from 18 to 16 with materials?
hi all
how can i transfer my model from arch 18 to archicad 16 with material ?
1 REPLY 1
Save as AC17 version in AC18.
Then open it in AC17 and save it as AC16. This is the only way.
However, GDL Objects will probably be missing in the backsaved file. Also, any element/data created with Tools/commands specific to AC17 and AC18 will not be there in AC16 since in that version they didn't exist.
What is not called a Surface was called Material in AC16. I suppose your AC18 Surfaces will save back to AC16 as Materials.
