I think it is not possible
From 2D views from each level you can do mod files by a publication
Then you can import them into your new pln and explode them if you don't need to keep modules
anto_bg wrote:
Is there a way to save the selection (selected with the thick marquee) to a new .PLN file?
Sure.
Place the all storey (thick) marquee.
FILE menu > External Content > Save Selection As Module.
Change the file type from .MOD to ,PLN.
Give the new file a new name and there you have it.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
I tried this yesterday and it didn't work. ArchiCad started a process of splitting the file and finally after a long wait to complete the process, there were two identical files with different names and that was it.
Yep, that is it.
The second file should contain only what was inside the all storey marque.
At least it does for me.
