Saving imported 2D CAD Drawing in the project
Hi guys, I drew a site analysis plan in a 2D cad application. However I would like to be part of my archicad project. I have not started to design anything yet, but I opened the CAD drawings natively with archicad and then copied and pasted it into a solo project. After I finished working i noted the the drawing is on level 1 in the project browser. So is there a way to maybe "save it as a view" or move it somewhere else within the project structure so that is it no longer drawn on level 1. Preserving the scale is important, but this is a drawing that for all intent a purposes has not relation to the model they way a 2D detail would. Which BTW, is this were a 2D detail, where would I place it so that then I can attach it to a specific part of the model?
2 different questions in one. Thanks a lot !
This is exactly the type of content the Worksheet Tool is for.
Create a New Independent Worksheet and copy-paste it into it.
You can also place it into the Worksheet Window with the Drawing Tool, if it is a DWG/DXF file.
If you need it later for reference, you can use the Trace Reference Tool in any of the Floor Plan Viewpoints to show it under that plan View.
