I can't say I ever use scale with plan very often but it will do just that.
The dashes in your line will increase/decrease with the plan so they will always look in the same proportion.
The dashes will get bigger or smaller but the number of them will stay the same.
With scale independent the dashes will adjust size (and number) so the line will always appear the same regardless of the scale.
The same with text - it either stays the same printable size (scale independent) so appears bigger or smaller as you scale the plan or the size will increase/decrease with the plan scale (scale with plan).
