Bob Moore
Schewed walls in Perspective
I was working on a project with a series of walls off set 3/4". after laying out the building and looking at it in 3d modes every thing was as it should appear. After adding site elements (sidewalks and mesh) I reviewed the project again in 3d and the walls appear skewed when shown in perspective but not in isometic, sections or elevations. By the way at one point archicad crashed during the rendering process. I can attach the pln. if that would help.
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
22 Replies 22
Just a screen shot or two might help.
Bob Moore
Two views are attached in seperate post
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
Bob Moore
Attached is the perspective with skewed walls
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
Bob Moore
I'll try again
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
__archiben
looks all right to me . . .
(perspective can look a little funny if you have the camera 'zoom' angle at either of the extremes . . . )
~/archiben
b e n _ f r o s t
To me, there is something very wrong with this perspective.
Shouldn't the Z vanishing point be above the building not below it ?
Peter Devlin
Bob Moore
If you zoom into the wall on the right you can see how the walls are nor aligned and the accent blocks which are in the same plane seem to go in and out in the face of the wall.
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
32 GB 2667 MHz DDR4
There's something going on. I thought at first it might have been due to vertical perpective, but it looks as though your camera is exactly horizontal. Can you try changing the view slightly, looking upwards a little, and see what happens. Might just be a resolution issue.
S t u a r t,
Are you seeing what I am seeing ?
The walls are tapering in the wrong direction.
Peter Devlin
