2003-11-11 11:42 PM
2003-12-05 02:24 AM
Karl wrote:True, but if it doesn't work a few quick (magic wand) subtractions isn't too bad.
Subtract only works for one polygonal element at a time - whereas split works for multiples. If you select multiple fills (or slabs, or ...) and try to do a subtraction, only the first one is affected.
With the split command, as Pete suggested,allfills can be selected, invoke split, then just click on the polyline and select a side. Quick and simple ... except for the split bug shown in the screen shot.
Karl
2003-12-05 06:32 AM
If you unlink, Link, you can draw a polyline for the grade level.I'm just not an un-linker - I just can't bring myself to do it!
2003-12-05 06:51 AM
Matthew wrote:I shouldn't quibble, Matthew, but hey, I'm 2 posts from 200 so I might was well get closer and see what three house icons gets me.
2003-12-05 08:26 AM
Karl wrote:Workaround: use MagicWand to create new polygons below the split line/polyline/curve/whatever and then remove the extra part of the original polygon.
In any case, there's a problem with the way that GS implemented the split operation with fills IMHO.
2005-01-23 07:27 AM
2005-01-23 07:32 AM
2005-01-28 05:17 AM
2005-01-28 09:43 AM
