Karel Landa
Home screen recent projects - purge missing projects
New home screen is good but I'm quite missing an option to quickly purge deleted/missing files.
What I would like is a simple button that will remove all projects that are missing (0 KB file size).
I'm aware that I can select multiple projects with shift or ctrl(cmd) and delete them but surely this would be small but welcomed addition.
From Archicad 17
MacBook Pro M1 Max
GG_rakurs
I would also like to see an option "Do not show again" to entirely skip the home screen. Why? Because if I start ArchiCAD and move away to a different task because it takes some time to load it, it will not load the work environment. On the home screen I have to select a task (New / Open / Teamwork...) and only then wait for the work environment to load. It's a waste of time for me and I would like to completely disable the home screen, at least the current version which I find lacking. Also, when opening a few instances of ArchiCAD, sometimes the home screen stops responding when selecting a task (New / Open / Teamwork...) and I have to kill the process for the Archicad Start specifically, after which it just goes into full Archicad without any problems.
ArchiCAD 28 | INT - Cro | Forward | WIN 10 / 11
