Section Rebuild Slow down
Is anyone else having this problem, when ever we create a section/elevation marker and initially cut it….the process occurs quickly….as soon as we add lines, text, delete items….the rebuild takes for ever…..is there a work around, or are we doing Is anyone else having this problem, when ever we create a section/elevation marker and initially cut it….the process occurs quickly….as soon as we add lines, text, delete items….the rebuild takes for ever…..is there a work around, or are we doing something wrong something wrong......
Djordje
r wrote:
Is anyone else having this problem, when ever we create a section/elevation marker and initially cut it….the process occurs quickly….as soon as we add lines, text, delete items….the rebuild takes for ever…..is there a work around, or are we doing something wrong......
Can you post a screenshot example of your average elevation?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
