Section doesn't show skin separator lines
I can't get the skin separator lines to display in my sections. What am I doing wrong?
The attached image explains it best, I think.
4 Replies 4
Erika Epstein
In general, Check over-ride fills and then you will have this option available.
I am not sure which wall you are unhappy with.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
None of the separator lines are showing, so it's all of them that I'm unhappy with. I've tried every variation on Model View Options with no luck.
Rod Jurich
LINZ wrote:
/.. What am I doing wrong? /......
Lindsay, you need to have a different name for the finish skin to show the separator line.
If the finish skin is to be the same fill as the core you will need to have a
different named fill, core fill 1, core fill 2.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Thank you very much! I didn't know that was the case...
