ā2010-12-25 12:44 PM
ā2010-12-25 03:32 PM
ā2010-12-25 03:40 PM
ā2010-12-25 04:00 PM
zeropointreference wrote:If I understand correctly the problem is the reverse. The fills are showing properly in plan and not in section.
It could be your floor plan cut plane is higher than your walls instead of cutting through them. Check under the Document menu, open the Floor Plan Cut Plane dialog, and lower the "Cut-plane height to Current Level" so it cuts through the walls.
ā2010-12-25 05:40 PM
ā2010-12-26 02:55 PM
ā2010-12-26 03:38 PM
ā2010-12-26 10:22 PM
Srinivas wrote:
I believe Structural display settings that needs to be changed from "Core only" to "Entire Structure" in your View settings.
ā2010-12-26 11:19 PM
ā2010-12-27 02:22 PM
