Select previous
Another very useful option that I am used to from other CAD programs is the "select previous". Lets say you pick some objects, then unpick those by a mistake, or you need to do another operation on those objects, do you really need to pick them again??
12 Replies 12
D_Sav
defo need a previous select.
ArchicadGuruWannabee
C'mon Graphisoft!!
We sent men to the moon in the 60's
We need select previous selection function.
Even Bluebeam has this function
This doesn't help if you accidentally deselect you items before you do this.
But if you think you are going to need that selection set again, simply group them.
Then with grouping enabled, select one element and they will all select.
