ares997
Selection Method
Is there a way to make the Selection method a shortcut (similar to geometry method which is "g")? I guess now that I look at it is would only be viable for the selection tool. In any event there doesn't seem to be a location where that is shortcut can be assigned in the keyboard shortcut area of the work environment.
Any ideas?
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
11 Replies 11
Srinivas wrote:
Samovar wrote:
When I select a load of different lines (some lines, arcs, poly-lines etc) to change to layer or colour: I find only one line-type has changed, so I have to go back and select arcs etc separately to change them.
How can I avoid needing to do this?
Here is now it can be done.
This will allow you to change colour and layer, but not linetype. If you have various elements, like lines, polylines and arcs all selected, click on the "Uniform settings for line tools" button, then change linetype.
Srinivas
Thanks for pointing on that Stuart, I guess I should have paid more attention before answering.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
