Selection Method
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2010-12-30 01:30 AM
Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-12-30 02:31 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-12-30 04:44 AM
This feature is described near the bottom of the article found in Archicad Help searching for "Selection Method"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-12-30 01:24 PM
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-01-10 11:59 AM
How can I avoid needing to do this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-01-10 12:21 PM
Samovar wrote:Here is now it can be done.
When I select a load of different lines (some lines, arcs, poly-lines etc) to change to layer or colour: I find only one line-type has changed, so I have to go back and select arcs etc separately to change them.
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-01-10 04:26 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-01-10 05:56 PM
Samovar wrote:Just to explain how this works:
When selecting multiple element types, the Info Box will show yo the settings of the last selected element. If you go to its Settings Dialog and make changes there or make changes in the Info Box, only elements of that element type will be affected. So it the Info Box show the settings of a Line, then the layer and color of only the lines will be changed, not those of arcs, polylines etc.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-01-10 07:14 PM
ares997 wrote:Took me a moment to figure out that you meant to type "shift"
You can also use the "Edit Selection Set" command (command+[censored]+T) and this will allow you to change the entire group's layers and line types.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-01-13 11:08 AM
Because of the impressive 3D and rendering stuff I think the 2D side of ArchiCAD is often overlooked: There is definitely an opening for a training package on the 2D drafting techniques. I think it could be used to wean the 2D devotees from their favorite CAD packages, I suspect that most drawings in the UK still originate in AutoCAD LT.
Control-[censored] should definitly be a comand option...
