Selection Method
ares997
Is there a way to make the Selection method a shortcut (similar to geometry method which is "g")? I guess now that I look at it is would only be viable for the selection tool. In any event there doesn't seem to be a location where that is shortcut can be assigned in the keyboard shortcut area of the work environment.
Any ideas?
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
11 REPLIES 11
http://archicad-talk.graphisoft.com/viewtopic.php?t=15126
AC 29 USA and earlier   â€¢   hardware key   â€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Dwight
In Archicad 14, the selection method can be determined by the direction of the cursor defining the selection area.
This feature is described near the bottom of the article found in Archicad Help searching for "Selection Method"
Dwight Atkinson
Eduardo Rolon
If you have used Autocad it is the same procedure.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
When I select a load of different lines (some lines, arcs, poly-lines etc) to change to layer or colour: I find only one line-type has changed, so I have to go back and select arcs etc separately to change them.
How can I avoid needing to do this?
Srinivas
Here is now it can be done.
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
ares997
You can also use the "Edit Selection Set" command (command+Shit+T) and this will allow you to change the entire group's layers and line types.
Just to explain how this works:
When selecting multiple element types, the Info Box will show yo the settings of the last selected element. If you go to its Settings Dialog and make changes there or make changes in the Info Box, only elements of that element type will be affected. So it the Info Box show the settings of a Line, then the layer and color of only the lines will be changed, not those of arcs, polylines etc.
ares997 wrote:
You can also use the "Edit Selection Set" command (command+[censored]+T) and this will allow you to change the entire group's layers and line types.
Took me a moment to figure out that you meant to type "shift"
Thanks Guys! This will save hours.
Because of the impressive 3D and rendering stuff I think the 2D side of ArchiCAD is often overlooked: There is definitely an opening for a training package on the 2D drafting techniques. I think it could be used to wean the 2D devotees from their favorite CAD packages, I suspect that most drawings in the UK still originate in AutoCAD LT.
Control-[censored] should definitly be a comand option...
