rengarch
Selection in plan/3D window
In AC9 you were able to select in the floor plan elements that you wanted to partially render in the 3D window. In AC10 I selected several walls from the model, activated the 3D window and the entire model renders in 3D. Did I inadvertently turn something on/off?
Rita MF Eng, AIA
iMac 27" 3.5 GHz Intel Core i7
NVIDIA GeForce GTX 780M 4096MB
MAC OSX 10.11.6
Archicad 20
Link
This is how it works in AC10, due to new functionality.
It's already been discussed here:
http://archicad-talk.graphisoft.com/viewtopic.php?p=61834
Link.
You can download an updated US work environment that sets the command/cntrl 3 key to display selected elements or those items in the marquee as it did in 9. I have started with this work environment and it seems like a good stepping off point. You still have full functionality of the new features in 10.
http://www.graphisoft.com/support/archicad/downloads/library_updates10/USA.html
