Selection tool not working properly
I am working in Achicad 10 and when I select an object then try to select its node to alter it, for some reason rather than grabbing the node, it selects another object that is touching that node and won't let me alter the original object without having to attempt it several times.
8 Replies 8
Eduardo Rolon
Use the TAB key to cycle the selection before clicking.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Ah, the infamous, "AC gratuitously changes your selection after you have made a selection" problem.
One solution is to move the target object a predetermined distance away, edit it there, then move back to original location.
Additional suggestions: turn off T&R, use layer combinations to work with fewer items on screen, zoom down to a gnat's patoot...
All a waste of time and mouse clicks to be sure.
sinceV6
Hi.
Perhaps what you are trying to do is:
1. Click to select object (with magnet on) using Arrow tool.
2. Click on node to start a pet palette edit. <- but AC selects the other object instead.
In this scenario, where several of the same types of objects are placed together, after selecting the first object, enter edit mode for that object either activating its tool or right clicking and choosing "select and activate tool". This way you will avoid your selection problem.
Hope that helps.
Also on the topic of the Selection took, some times my selection box disappeared and cant see the marquee that i try to create with my mouse.
any idea why this happens? how i fix it is shut AC down an reopen the file.
Try updating your video card drivers - that is usually the culprit.
I am guessing you might have the arrow tool active.
I have come across this in the past.
Archicad thinks you simply want to select something and the other object is what it wants to select first rather than edit what you already have selected.
Try activating the tool of the element you want to edit.
i.e. the wall tool if it is a wall you want to edit.
Use SHIFT button (SHIFT/TAB if necessary) to select the wall and then you should have no trouble editing it.
I will abide by your good suggestions and interpretation of AC logic.
BUT:
Isn't it buggy for AC to assume that the users' selection is NOT to be acted upon?
Eduardo Rolon
As far as I remember it is a bug that keeps popping up in every release.
One workaround is to select the object and right click on empty space this avoids the release and selection of the other object.
AC29 US/INT -> AC08
