Selective Viewing in 3d
I used to be able in AC9 to select an object in the plan view and see only that object in the 3d window. Now I see everything, with or without selection or using the marqee tool.
I know the setting is somewhere, but after much looking I can't seem to find it.
Thanks,
Don Lee
AC10 2-1.8G5
OSX 10.4.7
4 Replies 4
Right click to select the object or what is in the marquee for viewing.
Grant
I tried the marquee and all objects still show in 3d. Under View/Elements in 3d View there is a "Show Selection/Marquee in 3d" command, but that still doesn't do the trick.
I'm sure it is an easy thing that I am missing.
Thanks again,
Don
Dwight
Donnie:
What version?
Things are different in 10.
Check out the documentation.
F4 and F3 and Command-F3 and Command-F4 all engage or disengage a variety of view methods, and also restore views. I found it frustrating at first.
Dwight Atkinson
LiHigh
Dwight wrote:
Donnie:
The idea is good, but implementation SUCKs!
Howard Phua
Win 10, Archicad 19 INT
