canvea
Set roof pitch to 1% or less, different sides
Hi everyone! I am trying to use the roof tool to model a football field with a 1% pitch (or less) on four sides, however Archicad 23 only allows me to pick a 1,746% pitch, which makes the tool useless.. I assume the reason is that this number is hard to consolidate with all meeting points in the roof surface, but I would at least prefer that Archicad told me this, in stead of just reverting back to this annoying number 1,746 when I try to change it.
Is there a way to get the pitch to be 1% or less, and the four sides just adjusting to each other? If that makes sense. The sides don't all need to be the same pitch, just less than 1%. See attached photo for an illustration of my problem.
AC24 Norway • Fujitsu • Intel(R) Xeon(R) W-2123 CPU @ 3.60GHz • 32GB ram • Windows 10 Pro • NVIDIA Quadro P4000
David Maudlin
canvea:
Rather than the Multi-Plane Roof you could use four Single-Plane Roofs, which allow 0˚ angles. For a large terrain like this I would use the Mesh Tool.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
canvea
Thanks, I thought that's what I'd have to do.. Would be nice to have it as one single element though. And I'll add a signature!
