Set standing seam locations - Roof and Wall coverings
Can someone help me to set the locations of the standing seams on a roof and wall covering please. They are regular spacings but I need to be able to offset them from the end a certain distance
thanks
4 Replies 4
Lingwisyer
Guru
Just a query, how are you modelling you standing seams?
Ling.
MrC
I use the roof panel object .....
ILIFFE ARCHITECTURAL
BRITISH COLUMBIA
macbook pro 2.7 GHz Intel Core i7 8 GB 1600 MHz DDR3 NVIDIA GeForce GT 650M 1024 MB
AC 21 USA (latest build)
MrC
as in library 21
BRITISH COLUMBIA
Searching the forum with the Search function at the top will show years of discussion of this topic. The Accessories have not received any development effort during that period (they are officially unsupported):
Duane Valencia gave the first solution / tip many years ago:
https://archicad-talk.graphisoft.com/viewtopic.php?p=21019#p21019
More recently, Carsten gave a tip for 3D alignment:
https://archicad-talk.graphisoft.com/viewtopic.php?p=284327#p284327
