ā2008-08-20 12:48 AM
ā2008-08-21 08:39 AM
ā2008-08-22 01:19 AM
ā2008-08-22 02:32 AM
RandyC wrote:Rod Jurich is taking a look at it and we'll see what he comes up with before posting it to the depository.
Thanks Matthew , as time permits.....
Link , I hope to see this story marker as well , maybe in the depository ?
ā2008-08-22 03:38 AM
Link wrote:link, rod and rob
ā2008-08-22 06:39 AM
ā2008-08-22 06:42 AM
~/archiben wrote:And the interface.
/..other storey markers i've seen don't have this functionality - does yours/.
ā2008-08-22 07:20 AM
~/archiben wrote:I think mine does it but I would have to check (and I've shut down for the night). It is certainly possible. I must admit though that the tool is so limited it is hard to get excited about making it do backflips through flaming hoops.
(incidentally, as well as the reference levels, another feature i've longed for in this is the ability to offset the markerintothe extent of the section cut rather than out away from it. is that even possible?)
ā2009-03-03 10:59 PM
ā2009-03-04 10:43 AM
Matthew wrote:Matthew... YOU ROCK MAN!Link wrote:Like this?
Maybe a GDL guru here can modify the Built-in Story Marker
It's not a modification of the GS marker (which always seems more trouble than it's worth) but rather written from scratch (well actually adapted from my level line marker).
It's rather simple since the story marker subtype is pathetically limited in functionality; most significantly it lacks any dynamic hotspots to provide individual adjustments for length and offsets. Since the markers cannot be individually adjusted there is little that can be accomplished even with manually typed parameter values.
To be honest I think that the story marker feature is an embarrassing effort to match a Revit feature (which is dramatically superior) and is nearly useless as a result.
Features:
There are parameters to select the reference elevation and to choose between decimal feet, feet & inches, and meters.
The default font is hard coded to Arial and there is a parameter to override this and use the font from the pop-up list. If anyone wants to hard code a different font name there are instructions in the master script.
There is also a parameter to adjust the marker (called "Extend marker...") that will shift the markers' positions relative to the sections' extents.
ā2009-03-05 02:42 AM
Brett wrote:Brett, part attached. Will upload later.
Is Rod or Matthew going to kindly upload there markers?
