Sheet index order
Is there anyway to create a drawing list/sheet index that would list the Layouts in the order they appear in the layout book rather than by alphabetical order?
NandoMogollon
look for the "project Indexes" under your "project map".
There you can create, modify various types of tables / indexes far your project. You can make different lists: drawing lists, layout lists, and view lists.
Check it out, it is not hard to learn how it works.
Hope it can be useful
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Make sure the arrows are turned off in your index scheme
