kevin b
Shortcut Conflict Bug
So for I don't know how long I have had Shift + as bring forward, Shift - as move backward, control shift + as bring to front and control shift - as move to back and control + as go up a story and control - as go down a story with no issues. (these are keypad + and -)
Now in 10 I have the shortcuts set the same way but there is a conflict and control shift + or - moves me up or down a story just as control + or - does. I checked my shortcuts they are set the way I want them to work but it seems like if the control key is pressed the shift key is not recognized. And on top of it all, Option shift + Option shift - work as their control shift counterparts should even though they are not set up to be a shortcut to anything.
I realize I could change them but they are so automatic it makes my brain hurt to think about it.
Is this a bug or by design? If the former please fix and if the latter, why?
I have to think its a bug because of the fact that the command has switch to Option shift and I have another couple of shortcuts that are control = and control shift = and they both work correctly.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
0 Replies 0
