CIA20
Something wrong with 3D
Please help !
By chance I have pressed some keys and my 3D looks wierd 
as if something is cutting it off.
I need to desactivate it but can't find where. Would like to know also what shortcut did I presss to activate this function.
Thank you for your help.
CIArchitecte
Architecture et design
Setup info provided by author
2 Solutions
Botonis
Mentor
This might also be an object placed far away from the project origin.
Try to go to the floorplans zoom to fit with all the layers turned on to check.
Go to post
CIA20
Problem solved !
The issue occurred after I pressed some keys on my keyboard, causing two walls to intersect at an infinite point. Removing that solved my 3d.
CIArchitecte
Go to post
5 Replies 5
CosminF
From what I saw, it can either be a clipping plane issue or a OpenGL issue.
Maybe you can take a look here
https://community.graphisoft.com/t5/Libraries-objects/Problem-Unwanted-cutting-plane-appears-2m-in-f...
Possible solutions:
- switch to axonometric and back to perspective, see if the issue persists?
- rebuild the file (it may become corrupted)
- check the 3D style option settings - maybe it can help?
edit:
- it also may occur if your model is placed too far away from the origin - maybe check that as well
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Botonis
Mentor
Lingwisyer
Guru
Given the artifacts, I would assume it is a Project Origin issue.
CIA20
Problem solved !
CIArchitecte
Botonis
Mentor
Nice to see problem solved.
