yesterday
Please help !
By chance I have pressed some keys and my 3D looks wierd
as if something is cutting it off.
I need to desactivate it but can't find where. Would like to know also what shortcut did I presss to activate this function.
Thank you for your help.
yesterday - last edited yesterday
From what I saw, it can either be a clipping plane issue or a OpenGL issue.
Maybe you can take a look here
https://community.graphisoft.com/t5/Libraries-objects/Problem-Unwanted-cutting-plane-appears-2m-in-f...
Possible solutions:
- switch to axonometric and back to perspective, see if the issue persists?
- rebuild the file (it may become corrupted)
- check the 3D style option settings - maybe it can help?
edit:
- it also may occur if your model is placed too far away from the origin - maybe check that as well
yesterday
This might also be an object placed far away from the project origin.
Try to go to the floorplans zoom to fit with all the layers turned on to check.
5 hours ago
Given the artifacts, I would assume it is a Project Origin issue.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
