Shortcut for Display Order?
Is there a shortcut for alternating between the Display Order (bringing something forward or sending backward) of a selected element?
3 Replies 3
__archiben
yes there is.
depending on the version of archicad you're using (you haven't stated what that is), you can find what keystrokes are assigned in your work environment.
~/archiben
b e n _ f r o s t
Thanks for that.. I am using V11 and have printed the list of shortcuts out but cant seem to find the display order shortcut. I have jumped from V9 to V11 and found the shortcut in V9 which was F5 and F6 very useful. These function keys are now commands for other actions. If anyone knows the shortcut in V11 I would be most appreciative.
__archiben
you can assign them to be whatever you want in your work environment. see the attached . . .
(by the way - please place your machine/OS/archicad specs in your signature file so that people can better help you in the future! cheers.)
~/archiben
b e n _ f r o s t
