Shutters in Residential
I am placing a window in a brick wall with functional shutters on both sides of the window. ArchiCAD makes the shutters be shifted up an inch or so.
In real life the shutters wouldnt close into the masonry opening. We use functional shutters in our firm and need then to display correctly. Anyone have an idea of why the shutter makes that shift up?
6 REPLIES 6
Rick Thompson
This is probably no help. I will attach a screen shot of SmartParts windows. They may have more parameters to work with. I don't have AC's loaded, so can't check.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
Erich
I have a similar problem with AC's library. In my case I just make a library part or two and place them manually. Although it can be a pain when things change, houses aren't too big...
Also you might want to check out ACE's library, http://www.archicad.ca/ , there might be something there that could work although I have not looked.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Thanks, our BIM manager made a custom object for us and it works like a charm.
David Larrew
Geez... Thanks, Lee
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
You're Welcome, Just send me the money for giving you props in an envelope.
You gave him props in an envelope?
