ā2009-06-16
10:17 AM
ā2023-05-23
04:54 PM
Rubia Torres
ā2009-06-16 11:01 AM
numerobis wrote:ArchiForma -
or is there any plug-in or something to get this feature in AC?!?
ā2009-06-16 11:03 AM
ā2009-06-16 07:49 PM
ā2009-06-16 08:03 PM
numerobis wrote:If you're just talking about 2D work, the concept is similar - you just do not use double-click to open the 2D object ('block') - you select the object and use ctrl-shift-O (or assign this shortcut to Open Object if it is not). Then edit the symbol, save, and all placed parts are updated, just like an autocad block.
Thank You!![]()
but i'm searching for a solution for the normal 2d-work for every object that is used several (or many) times in a drawing. in acad/sketchup/vw... i can select some objects and use "make block" (or component or symbol) and without any other work i now have a block that than can be edited by doubleclick or rightclick/edit...
so my question was, how do you work in AC if you want to use objects several times and be able to edit them quickly!?!
ā2009-06-17 11:44 PM
