Site modelling , show site ground change in plan mode?
Hey!
Im working with a site which ive modelled with mesh-tool!
Ive modelled 2 meshes , 1 shows ground before , 1 ground after modification
Ive used solid element operations to cut out the mesh that showes the ground after modification so it only has the spots thats been hightened. This works fine to display in section and 3d , but in plan view it doesent matter what i try the cover fills for each mesh covers the whole damn square and ignores how they overlap.
I need to show in plan the ground parts whitch has changed , have i missed anything!?!
Cheers!
/DJ
Solid Element Operations do not show in plan unfortunately.
What you could do is convert it to a morph and then you will get the true 2D top view in plan.
Maybe morph a copy of the SEO just in case you want to alter it later and hide the SEO in a hidden layer.
