Sketcher in version 8
I am wondering if anyone has used the new "sketch" feature that 8 offers? How does it work and should I upgrade from 7 for it?
1 REPLY 1
Petros Ioannou
Sketch render is a rendering engine which can make your PC crawl.
In my opinion a 3d presentation improvement doesn't qualify as a reason to upgrade from 7 to 8. There are other applications to achieve the same and even better "3d" results. On the other hand improvements such as Solid element operations, Project Navigator and better Plotmaker functionality are serious reasons to upgrade.
To be more specific about sketch rendering, it can produce nice sketches, even on the first stages of a project. It's better to check it yourself at the nearest graphisoft reseller.
HTH
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
