Skin Priorities and 3D Documents
Craig Bagley
Do Skin Priorities work in 3D Documents? I can’t seem to get them to. The attachment below shows the same intersecting walls in Floor Plan and 3D Document windows.
The walls both have the same Wall Priority (the N-S wall was drawn second), and have ā€œEnable Skin Prioritiesā€ checked. The appearance in the 3D Document window is as if ā€œEnable Skin Prioritiesā€ is unchecked.
The Reference Guide suggests to me that Skin Priorities work in the 3D Document window (p 890, second subsection: ā€œ......and the 3D Document window,......ā€).
AC27 USA/Build 5030 16" MBP
Katalin Takacs
Dear Craig,
thanks for your observation.
At the moment this is a limitation in 3D Document. We are aware of this issue and the development of Skin Priority display in 3D Document is scheduled to be achieved in a further version of ArchiCAD.
Best regards,
Katalin Takacs
Craig Bagley
Thanks, Katalin!
