sarahric
Skylights in plan
Ok, here is the problem, my skylights are not showing as I would like in floor plan and roof plan.
The roof is set to home & one story up / projected w/overhead / entire element as I want to see it with cover fill on roof plan and as dashed outline in floor plan.
The skylights in the roof are showing on the roof plan but with no marker and no label. Model view is set to show the marker.
In floor plan they are showing as solid lines, (overhead lines set to dashed) with no marker, but a label can be added.
I want the skylights to show with pivot and marker on the roof plan, and dashed with marker on the floor plan.
ArchiCAD 18/Windows 7/16GB Memory/i5 3.2GHz Processor/NVIDIA GeForce GT 610
I am having this problem as well in AC16; were you able to resolve the issue, or did you discover a workaround?
JK
sarahric
Just had to work around the issue. Got it to show ok on the roof plan, via object floor plan display, renovation and model views, and then draw polylines on the floor plan.
