Slab/door intersection problem
Hi everyone,
I've got one issue with the intersection between door and slab. The issue is that when I apply a door into a composite wall, it overlaps the slab and it appears like the picture in the attachment. Can anyone give me a hint? I can easily solve this by changing the wall position, by putting it 30 millimeters higher, but then the wall doesn't connect with the main slab.
Thank you so much for your help,
Marco Coelho
1 Reply 1
Hi again,
After a while, a figure it out... priority issues
Thanks Anyway
