Soffits...
ksjhawk
How do people tend to model drywall soffits? I have a wall in a room that has an area that is set back 4-6" which creates a soffit condition that I'd like to render properly in a building section. I've tried using the same wall type as a slab, but cannot get the elements to heal. Is there another technique that is more convenient?
Thanks in advance...
MacBook Pro Apple M4 Max 128GB ram
OS X 13.6.7
AC28 - AC6.5
1 REPLY 1
I use custom walls with wall profiles. w/ vertical and horizontal stretch on. As you can see I have the framing-structural sheathing, drywall, and crown all included so it looks good in rendering and also in sections. Change the wall to dashed lines in the floor plan.
