kristoftihanyi
Stair upper connection error
Hi!
I have the following problem with monolithic stairs with stepped soffits: Vertical connection doesn't take stair covering into account and instead the structure and the covering overlap. Also the structure protrudes upward by 2 cm-s (in this case that's the thickness of the covering, but changing that doesn't affect this protrusion, so it's a coincidence).
Please fix this bug.
Operating system used: Windows 10
0 Replies 0
