Solid Element Operations problems!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2006-09-06
01:30 AM
2023-05-23
03:26 PM
Rubia Torres
I have had the problem before with meshes, and I copied the mesh and replaced the old one and then it worked, takes a few times of copying and pasting.
Acton Design Services
Windows 10 PRO 64 bit
i7-5820K @ 3.30ghz 32GB Ram
Nvidia GeForce GTX 1650 4GB Ram
AC 19 - AC 28
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-09-06 04:31 AM
by SOE'ed, i think you mean "trim to roof"? and then after you've moved the roof around, up or down, the wall stays trim to how/where the roof was.
if that's the case, then to reset the wallto its original state so that you can re-trim. pick the wall, go to its 'wall selection settings' dialogue box. there's an option in the 'model' section of the settings called "undo roof trim". that should reset the wall.
Minh.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-09-06 06:13 AM
SEO is used as an alternative to "trim to roof" and stays linked, i.e. if you alter the roof the wall "cut" moves to suit. Both methods have their merits and drawbacks. Gerald "Toofuerte's" problem is that these changes are not being updated as they should be. Of course if you delete a roof which is used as an "operator" then create another roof in its place the SEO is lost, but I don't think that is the case here.
(or are you saying Gerald has "trimmed to roof" but is describing it as SEO?)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-09-06 01:36 PM
Steve
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-09-06 04:53 PM
AC 19 - AC 28
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-09-06 05:33 PM
Thanks,
AC 19 - AC 28
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-09-14 10:10 AM
Can send file if anyone wants. Regards
Fred
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-09-14 10:20 AM
Broker wrote:Dont forget they need to be on separate layers and then hide the cookie cutter
I have 2 copies of non-rectangular multi-sided slab. One is offset inside the other and I want a Boolean subtraction. Can't get it to work.
Fred
OSX 10.15.6 [Catalina] : Archicad 22 : 15" MacBook Pro 2019 [/size]
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-09-14 10:45 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-09-14 12:12 PM
