Solid operation problem !
I have this problem
I want to sub.with upwoard extr. and this use to work all the time but now i always get this wall above, look at pic.
Roof is created in archiforma, is that a problem ???
12 Replies 12
2pic
Thomas Holm
Maybe. If the roof isn't solid, that is it is only surface and no substance, it will not work as an operator. But to me it looks like it works in reverse, someway. Perhaps a bug with the 'normal' vectors of the surfaces. What happens if you reduce the original height of the wall (before SEO) as much as possible?
same thing . . .
i hate when i cant finsh my job cos of some bugs
Thomas Holm
Weird. In your pic 2 it looks like the SE operation Subtracts, but without the upwards extrusion. Also, it seems to subtract a much larger thickness that the Archiforma roof displays.
My guess is the fault is in the Archiforma code. You should ask Cigraph about it.
In the mean time, you could use a hidden slab or something to Subtract with upwards extrusion the remaining wall part in the first situation.
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Send me the object and I will check it...
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
Cutting element should have higher priority than elements to be cut.
Friendly
Fabrizio
i will sent u my file, and i want to ask u something more. (later today,must leave office now)
Most time i dont create archicad objects when i model something in ac (modeling in archiforma), cos i always change something . . .
So in first version i create truss from fill, extrude it, and i dont create object from it, then later i open second new file in ac and i put truss from first file in it. And its ok, truss is there but im not able to edit it in this second file, i must return in file in which i create it to edit it. I hope that u folow me, this is very anoying for me. . . . and in this second file im not able to create archicad object from that truss. . . only in file in which i create this. So this mean, i cant change nothing, and if i want i have to draw and extrude new one to be able to edit it in second file
Be back in 1 hour !
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
do you mean you inserted the object (in the second file) as module?
Or did you simply copy and paste it from the original file to the second one?
Friendly
Fabrizio
Fabrizio Diodati
Friendly
Fabrizio
copy - paste !
Then i open archiforma, addon recognize that it is archiforma object but i cant edit it, or create gsm object ???
