Some slab intersect and some don't... I need them to look smooth instead they show lines
cocoloco
Hi! Could someone help? I am building mantel fireplace. I am using ONE material of slab, and all is aligned. all is set up same except different heights. as you can see in photo. The upper mantel DOES NOT intersect (it is showing line...) which I hate. I tried everything.... and then I did mantel under it, and it dit intersect. And that's how I want all these slabs to look like.  I don't know what is different because as I said all slabs are same settings except the heights.
PINK = showing line and I don't want that
GREEN - not showing line and connects properly. that's how it suppose to be.
Thank you
Operating system used: Mac Intel-based
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
vistasp
Is it possible that the front face of the horizontal slab is not exactly in line with the vertical supports? Even a fraction of a millimetre difference will cause a line to show up.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
1 REPLY 1
vistasp
= v i s t a s p =
bT Square Peg
Setup info provided by author
