Something stuck in Workspace..Please Help
Attached is a picture showing stuck object in workspace.
The Inverted L shaped thing is stuck at same location and wont go.
Help appreciated. Thank You.
3 Replies 3
Draw a marquee around the items to highlight then delete.
The layers may be locked when selected if so unlock then delete.
David Maudlin
Prachibkhd2408:
It might be a Trace Reference, check the Trace & Reference palette.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Spot was stuck on screen and it showed above everything on screen just in workspace.
Resolved by Changing work environment.
Thank You for helping.
